Hey All,
How easy is it to remove the front seats from a 1998 6n??
Looking for a bolt of some sort but cant find anything??
can anyone help please?
How do i remove front seats from POLO??
polo gangsta
as gangsta says its easy. Slide back undo and then your near enough off. One thing he missed was the plastic ends to the rail. They just pull off. theyre pretty brittle usually. I broke both mine cause they were a pain lol. Dont make no difference to the seat so b*******s to it haha.
one other thing is try and keep the white greased bit of plastic in the middle on. youll see what i mean when you get the seat off. can be a bugger to get back on if it comes off.
From one of my other threadsTo remove:
Put the seat fully back on the runners. Remove the allen key headed bolt and recover the nut
Then put seat fully forward on runners, and remove the end clip closest to the door side and the plastic guide on the other runner. Note this is very fragile, and can snap with little to no pressure.
Then put the seats all the way back on the runners and they will just lift out with some gentle persuasion.
Mind the grease though - its horrible stuff, and is a good way to make you need a replacement carpet fast!!
