help me !!
tErrybOi
help me !!
Post by tErrybOi »
hi everyone
u could call me a NooB to this site. i just bought a polo coupe 1.0l its dark blue..and looking at this site has inspired me ! U guys av some fine cars man. i need some ideas on alloys. what tyre size will fit without me having to cut away the wheel arch. ideally i'd like to stick 15" or 16" wheels on, but im not sure what will fit. is there any other sites except radesign.co.uk that deals with flush bumpers etc ?
any help would b appreciated peeps.
cheers
terry.
LogIK
Post by LogIK »
Check out my post here
You'll find that you will need to stick to the following specs:
14" x 6" or 15" x 6.5" (Diameter x Width)
100mm x 4 Stud PCD (Pitch Circle Diamater)
ET 36-38mm offset
SpikeyG40
Moderator
Post by SpikeyG40 »
hey welcome to the forum, i got 195/45/15's tyres on 15x6.5 alloys! they look really good and as far as i no, i am the only one who has had problems with alloys! i am running them with 3mm spacers n they rub on the right hand rear suspension when giving it some around 3 hand corners! no one else has had problems!
o and if i were u, i would look into getting it lowered as well, i am waiting for some nice weather to put my springs on
hope this was of some help! welcome to the 1.0ltr club! :lol:
dub envy
Moderator
Post by dub envy »
15x7 will fit with no rubbing....
hardhitter
Moderator
Post by hardhitter »
If you are lucky, and with standard suspension. Lower it and it will start to rub, you can almost guaruntee.
Gilex
Drives: 6R 1.4 (2010) & 6R 1.2 TSI (2012)
Post by Gilex »
hardhitter wrote:If you are lucky, and with standard suspension. Lower it and it will start to rub, you can almost guaruntee.
Jep, Even with 6x14 ET38 with 40mm lowering will start to rub, I had some rubbing with 185/55 rims if you want 14 inch wheels go for 195/45 and mod your arches
dub envy
Moderator
Post by dub envy »
Gilex wrote:Jep, Even with 6x14 ET38 with 40mm lowering will start to rub, I had some rubbing with 185/55 rims if you want 14 inch wheels go for 195/45 and mod your arches
do you mean 15 inch?? because you can't get 195/45x14... can you??
hardhitter
Moderator
You can get 194/45 14 tyres. But 185/50 14 are possibly more suitable, thats what I'm fitting to mine next. Strange enough as it sounds, but 194/45 are cheaper than 185/50.
SpikeyG40
Moderator
Post by SpikeyG40 »
the 45's are more expensive because they are a lower profile! don't ask me y, i guess its to do in the manufacturing of em! i hope i don't get any problems when i lower mine! :?
Speedlaw
Moderator
Post by Speedlaw »
I was led to believe that tire prices are a result of production numbers. 195-45-14 is quite popular here, so they're not that expensive.
Consider the difference between 195-50-15 and the 45 series version, in which the latter is way, way more expensive than the higer 50-series version.
Mogwy
Post by Mogwy »
Hey guys im new here my polo is in my sig hopefully if iv done it right lol anyway iv got 15's on mine 195-50's and i don't get any rubbing
