the battery is clamped down and very secure
the box is a slanted back box, but with the long side 3" away from the back seat, ie its upside down and bolted thru the rear arches to allow for fitting 5 cubic ft in and the rather large battery
for now i have an Atomic four channel and also a rather small class d (the big one at the bottom) that will do 3k rms into the subs, which at the moment are jbl GT5 12", these will load the amp at 2 ohms and get roughly 2k rms (not bad for a pair of 300 watt rms subs)
the box is roughly 5 cubic ft and will be tuned to 28 hz by a 6" aeroport (basically a tube with large flared ends for better airflow)
the car from the outside
