Amp Mounting
Discuss In Car Entertainment
Q86ARR
Amp Mounting
Post by Q86ARR »
Is it ok to mount an Amp upside down?
Tim_GTi
Post Whore
Post by Tim_GTi »
no, it will overheat
dumdum
Post by dumdum »
Tim_GTi wrote:no, it will overheat
i will answer slightly more constructively, which amp (some are ok being mounted upside down) and what will the amp be running? and how well set up is the amp? ie if its for subs has it been anywhere near an oscilloscope to check its not clipping? :D
david burton
Post by david burton »
good point - would a Genesis Profile 2 be OK upside down? It has a built in fan....
dumdum
Post by dumdum »
david burton wrote:good point - would a Genesis Profile 2 be OK upside down? It has a built in fan....
i would have thought that may well be ok as long as its not being hammered on a sub, all day everyday :)
Q86ARR
Post by Q86ARR »
I've got a 400W JBL GTO200 that has been running a 12" 1000W JBL sub. But now it will be running my components and I'm in the process of looking for an amp to run my sub.
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
you can stick it in your rear quarter cards if yours is a 3door
