Polo clutch pedal problem
When I screwed a pedal plate onto my 04 polo, I first had to remove the rubber cover on the clutch pedal. When I pulled it off, I smashed a small part of the small blue bit that holds the clutch pedal down at the place where it starts to engage with the pin that can then engage/ disengage the engine. So the clutch itself is just the same just the pedal is practically horizontal. Does anyone know how much a new blue piece would cost and how much labour it would take to fit?
