mk4 1.4 cl, acceleration hesitation
hi all i have a 1.4 cl, jst recently brought it and having a few problems with it, when accelratiing the car seems to judder through accelration, when the car is in neutral its revs absolutly fine? help
poor revs
Hi mate like i said last hight my polo same ass yours was doing same it would rev like hell out of gear but put it in gear and it would judder like it was trying to pul pet through .I was told to change h t leads sparks pet filter or temp sender i did all this the plugs was last thing i changed and it hapend to be the plugs giving my polo the same probs ass u got but may be it is one of the others on yours the man who help me was an expert with much experience his name is alex perkins he is prob on line give him a shout hope u r as lucky as i was to replace all parts cost me less than 30 pound alot cheaper than tacking her to v w steelers
Fluffmarten
mine sometimes has a similar problem, causes the rev counter to go mental, happened after a recent gearbox, driveshaft and cat change, not too much hassle as it only rarely does it. 1400 miles with the only problems being a dodgy exhaust and taillight wiring. either goin back to a Mk3 or gettin a honda civic
kagaraneon
- Drives: VW POLO 1.4
Re: mk4 1.4 cl, acceleration hesitation
Hi guys.
I experience the same issues.
VW Polo 2002, 1.2, petrol.
Fuel filter was changed, air filter was cleaned...what else can I do?
Alex Perkins can help please?
Change your spark plugs and if that doesn’t fix it, the three coil packs.
kagaraneon
Thanks Alex.
I just went last week to the garage.
They said the spark plugs were okay.
One coil was defect and was changed.
Should I still go ahead and change the spark plugs?
Don’t always trust garages and what they say. If one coil he failed the others are often on their way
kagaraneon
Thank you again!
How do I check if coil or spark plugs are bad?
You’d have to look at the spark plugs after they are removed one by one and assess the electrode condition and the color of the tip
Coils are hard to check. It’s normally a case of just replace as there’s only three on your engine
