Hi guys,
just ordered a couple of new wingmirror covers from VW - and a can of red spray paint.
as they already come primed i guess i just build up light layers of paint yeh? do i need to sand em in between? and then is it just a case of spraying laquer on top?
just want to make a good job of them!!
thanks for any advice guys
painting advice
- Tim_GTi
- Post Whore
I'd advise taking it to the bodyshop too,
I painted mine myself at first, starting from scratch
once full primed I applied several layers of paint, only sanding down every 3 coats or so (using 1200 grit i think?)
Then you gotta apply heavy coats of laquer, its hard because if you apply the coat too heavy it drips (absolute b*tch when that happens!), I sanded inbetween coats on these, and couldn't get the finish right so eventually gave up and took it to a professional who did it for £16!
