Removing Rear Door Cards
TheEggShell
Post by TheEggShell »
Hi all,
Can anyone tell me how to remove the rear door cards on my polo gti?
Tim_GTi
Post Whore
Post by Tim_GTi »
3 door or 5?
TheEggShell
Ah, yeah. I can see how you might need to know that :roll:
It's a 3 door.
Just out of interest, do you also know how to remove the front door cards aswell?
Tim_GTi
Post Whore
Post by Tim_GTi »
Couldnt help you on the rears sorry mate, I own a 5 door,
For the fronts take a look at this guide
http://www.tigerstyle.co.uk/poloforum/v ... light=door
polo_gti21
Post by polo_gti21 »
for the 3 door remove the bottom part of the seat and pull the back rest down you will need to remove the seat catch with an allen key there is also a cross screw down by the seat belt floor fixing area and a few panel fixings things located under the seat you just undo these 1's with your hand then just gently unpop the door card trying not to break the clips and lift up sightly.
Three door - there is a screw near the bottom on each. You need to remove that, then remove the seat bolt via an allen key. You then pull them off from the top carefully as so not to snap them in half :P
edit: haha cross posting there!
