UK-POLOS.NET - THE VW Polo Forum • Removing Rear Door Cards
Posted: Fri Feb 01, 2008 12:32 pm
by TheEggShell
Hi all,
Can anyone tell me how to remove the rear door cards on my polo gti?
Posted: Fri Feb 01, 2008 6:01 pm
by Tim_GTi
3 door or 5?
Posted: Mon Feb 04, 2008 8:58 am
by TheEggShell
Ah, yeah. I can see how you might need to know that :roll:
It's a 3 door.
Just out of interest, do you also know how to remove the front door cards aswell?
Posted: Mon Feb 04, 2008 7:16 pm
by Tim_GTi
Couldnt help you on the rears sorry mate, I own a 5 door,
For the fronts take a look at this guide
http://www.tigerstyle.co.uk/poloforum/v ... light=door
Posted: Mon Feb 04, 2008 7:27 pm
by polo_gti21
for the 3 door remove the bottom part of the seat and pull the back rest down you will need to remove the seat catch with an allen key there is also a cross screw down by the seat belt floor fixing area and a few panel fixings things located under the seat you just undo these 1's with your hand then just gently unpop the door card trying not to break the clips and lift up sightly.
Posted: Mon Feb 04, 2008 7:32 pm
by alexperkins
Three door - there is a screw near the bottom on each. You need to remove that, then remove the seat bolt via an allen key. You then pull them off from the top carefully as so not to snap them in half :P
edit: haha cross posting there!
