help! replacing headlight bulbs!
asim2k2
Post by asim2k2 »
i recently bought some H7 headlight bulbs to shine a brighter white light than the ones i already got. now ive looked hard into how to take my lights out but i have no clue on how to replace a simple bulb!!!
ive got a new shape mk7 (9n2) polo!
what do i dooo =S
many regards
Andrew
PatchySan
Post by PatchySan »
It got me stumped at first but its pretty simple to do once you get the hang of it. First have access to the engine compartment, where the headlights located there should be a rubbery black cover at the back of the headlight unit. Take out the big circular cover. Now with the black headlight holder, gently twist it (I think its anti-clockwise, if not try the other way round). It should twist off from the holder and you have access to the bulb if you guide it out. Take the H7 bulb out and carefully replace it with the new (try not to touch the glass). Then reverse the steps and it should be fine from there on.
bstardchild
Moderator
Post by bstardchild »
Bumped to the correct section
