having troubles ?????
milky1234
Post by milky1234 »
Hi all
im having troubles with putting car into reverse. It feels like its in gear but then when i go to pull away it makes a horrible crunch noise then comes back out of gear. but im only having trouble with putting it in to reverse and 1st gear.
andyg
Post by andyg »
It could potentially be the Pedal box, you could do with reading up on that thread:
http://www.tigerstyle.co.uk/poloforum/v ... =pedal+box
Failing that it could be the gearbox, or your clutch. First I would check out the pedal box, then I would move to the clutch and box.
Good luck and keep us posted.
mwarner87
Post by mwarner87 »
i had a similar problem, all that was with mine was a bolt missing from under the bonnet, might have been around the gearbox
go n get it looked at
Si_GTi
Moderator
Post by Si_GTi »
First (and cheapest!) thing to check would be to have the clutch cable adjusted. I suffered the same symptoms after having a new clutch, the cable needed adjusting. Since adjustment, it has been perfect! :)
