Mouse_GTI wrote:Second is rust! Yes on a 2 year old car! There is a 1cm bit on the bottom of the passenger door started rusting, and the point on the sill directly below it has also started rusting
Ditto!!
Our 2 year old has that same problem.....I think. On the driver's side.
Looks like the door hinge has dropped and it's catching at the bottom on the sill as you close / open it. Our abrasion mark is about the size of a stamp.
This is unacceptable for a car that's only done 24K (in our example). My Corrado has only just started doing that at 160,000 miles.
We're taking ours back to the dealer for rectification. It should be covered under warranty? I suspect it's a design flaw and there's probably others out there that haven't spotted it yet, especially on silver cars!
