Heya,
I wont be the first to say, that the oem speakers in the tweeters and doors suck. I'm using a sony head unit right now and I don't think I can handle listening to tinny, trebly, thin sound. I'm on a budget of around £60 and I'm looking to upgrade the speakers in the doors and front tweeters. Does anyone have any experience with replacing the stocks for something better?
I listen to rock music mostly so I wont really be needing a sub. Sorry if this sounds amatuerish because I am, but I've done a few mods before and reckon replacing the speakers shouldn't be too much of a problem.
Replacing speakers on my 6N
- Tim_GTi
- Post Whore
changing speakers is dead easy!! If your after something better but nothing big, then you can just use the original speaker wire. i'd recommend something like these
http://www.caraudiodirect.co.uk/alpine- ... 6348f8658b
BratManGTi
Re: Replacing speakers on my 6N
well my advicePolo96CL wrote:Heya,
i started my polo 6n sound system last year
ended up with a system of around 3k
get adictive lol
best thing for budget is
get down to your local motorworld and get a set of 17cm JBL gto 2 way speakers for the front £30
and 6x9 JBL GTO also for £30
easy to fit
great sound
do not worry about wires
your running the speakers off the head unit amp 4x50w i guess at the best
you dont need any bigger wire for the front as the vw wire is just over the top anyway
i run 6 2 way sony boston edition speakers and and 2 bluabunkt tweeters
throught 2 kenwood 1000w 4ch amps for the front
sounds great and the wires handle it fine
the rear cable that comes with the 6x9s will show you what i mean they are very thin
but do you think a multy million doller comany would give out crap wire
dont think so
if u want some more help let me know dude i will send u some pics
- ticki
- Sponsor
Could i use these as a direct replacement, and not use the cross over.Tim_GTi wrote:changing speakers is dead easy!! If your after something better but nothing big, then you can just use the original speaker wire. i'd recommend something like these
Its for my my 6n2 which already has wiring for front tweeters and mid speakers
- ticki
- Sponsor
Also would these fit no problem? very good spec.
http://www.caraudiodirect.co.uk/pioneer ... -3265.html
I'm also wondering what the OEM speaker RMS power is?
lorenzodr
- Drives: Volkswagen Polo 6n 44kw 60 pk
Hi I have a 6N, and i have bought new speakers but the old ones have 4 wires and the new ones 2 wires, how i must connected it
The additional wires are the feed back to the woofers. If you follow the wiring, you can find the split and put a crossover in its place
