car constantly needing water
lpmucks
Post by lpmucks »
hey guys got a 1.4cl and recently ive been finding i need to put in water every two days near enuff. Any ideas of what i should do?????
any help appreciated :D
iggy350
Post by iggy350 »
jus outta curiousity m8, is ur Passenger side or Drivers side carpet wet?, if it is then it looks like ur heater matrix has gone. If not then look under your car for water leaks, could be your Radiator, or if u have got it, your AC.
that failing, could it be your head gasket? im not sure if that has summut to do with water or oil, i always forget. Anyways a quick check is jus to open you oil cap and see if theres any white reidue there. But it could have nothing to do with water like i said i cant remember.
Hope this info helps m8
PS
if it happens to be a leak on the heating matrix/ Radiator, before u go all panic stations lol go buy some RadWeld and put it in the Water tank and leave your car runing for 15 minutes or so, it fixed mine :)
lpmucks
Post by lpmucks »
hey cheers for the help :D :D
no my passengers side carpet is not wet
yer i was thinking of try some of that radweild stuff
also i read the haynes manual and it said that there is a special type of coolant that vw put in something like g12 or summit and it shouldnt need replacing might try getting some of dat dunno where from though ..... any1 got ideas???
sylvester
Post by sylvester »
You'll get the coolant from a stealer or possibly an independant vw garage. Have a good look over the engine/ hoses for any leaks and look around the water pump for any signs of leakage too, but at that mileage it could be the cylinder head gasket.
dragon_green
Post by dragon_green »
You can get it from places like GSF or eurocarparts too.
Are you sure you want to use rad-weld? I'd only use it as a get-me-home. It's not a fix.
BratManGTi
Post by BratManGTi »
sylvester wrote:You'll get the coolant from a stealer or possibly an independant vw garage. Have a good look over the engine/ hoses for any leaks and look around the water pump for any signs of leakage too, but at that mileage it could be the cylinder head gasket.
just use a prestone coolant
get it from motorworld big yellow tub
it mixes with any type of coolant for any car
Biddle
Post by Biddle »
This has happened to me and it was my radiator. Just go to a garage and ask them to pressure check the system.
