Bought a Lemon! need help please
frankeygsxr1000
So bought a 2001 polo gti 2 weeks ago so cause the milage was quite thought i'd take it for a cambelt change and get it plugged in as a abs&engine managent Light was on.......
needless to say my mechanic rang me the next day with the usual "are you sitting down" trouble been he meant it this time..
(sorry if this message is going on a bit people)
Right here goes...
-cam guides collasped
-gear box leaking oil
-steering rack arms loose
-abs outside tollerance
plus loads of other sillly little things !!
so needless to say the i rang the garage and they agreed to honor the engine and gearbox waranty
So i rang vw for a abs pump price £657inc vat i mean is thing made of gold&diamond encrusted????
So i'l cut to the question if anyone can help my pump no is 6x0614217 i've seen one on ebay off a polo 2001 part no 6xo614117 will this still work or are GTI one different...
Sorry to go on but i really love the car and it's really gutted so just wana it get it sorted plus my M.O.T due in less than 2 weeks so need the abs sorting out
Thanks for looking Lee
Right here goes...
frankeygsxr1000
- Tim_GTi
- Post Whore
Did the garage actually investigate and check the pump?
If they're jsut going by what vagcom picked up its likely to just be a sensor or two.
There's a connector leading to one underneath the rear bench on the driver's side, if you unplug and plug back in the connector it should be fine, not sure about the other one though
frankeygsxr1000
frankeygsxr1000
frankeygsxr1000
Re: Bought a Lemon! need help please
frankeygsxr1000 wrote: So i'l cut to the question if anyone can help my pump no is 6x0614217 i've seen one on ebay off a polo 2001 part no 6xo614117 will this still work or are GTI one different...
I suspected they'd be different, and the EDS possibly refers the Electronic Differential Lock which only the GTI hasFrom vagcat.com wrote: 6X0698117
hydraulic control unit with attachment parts
ABS+ / PR-1AC
6X0698217
ABS+EDS / PR-1AH
