Lowering messing up tracking/camber etc
Biddle
Post by Biddle »
Hi guys.
I recently lowered my polo and now its pulling badly to the left. I always assumed I would have to get tracking done so no biggy.
What about the camber? I have always been under the impression that it is not adjustable on the polo.
But I know there are cars on here that are lowered more than mine.
Does/has anyone else had a problem with camber? If so what can be done about it?
Please post any suggestions.
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh its quite a known factor that once your car's lowered you've got to get the tracking AND camber re-adjusted, it can be done on the polo,
Apparently though if your car is too low there's nothing that can be done.
They should do the camber same time as they do the tracking, average price is around £40 for the lot.
The_phat_controlleruk
Post by The_phat_controlleruk »
^^^^^ What he said, mine cost 50 squids to get the back and front set up. Mine's lowered by 80mm so had no probs, they had to use hub centric aligners on mine (not sure what the proper name is) as they couldn't get the other type under my arches. Of course, your car needs to be able to get on the ramp, so if it's to low, then I can see that being a problem.
Biddle
Post by Biddle »
cant do tracking on mine because the wheel will hit the inside of the arch if straight :cry: it will have to go back up unless i can find some 30mm springs soonish.
Tim_GTi
Post Whore
Post by Tim_GTi »
How low are you exactly at the moment?
Biddle
Post by Biddle »
I dunno to be honest. The pics of the passenger side I posted show the arch sitting above the wheel, unfortunately not the same on the drivers side.
Im going to take it all off sell it and get coils probably as then I can adjust.
This is the same with mine, I just learn to live with it to be honest, although going the coil over route is probably best.
Tim_GTi
Post Whore
Post by Tim_GTi »
Biddle wrote:I dunno to be honest. The pics of the passenger side I posted show the arch sitting above the wheel, unfortunately not the same on the drivers side.
Yeh sorry, I didn't know it was your car in the other thread! Coilovers does sound a good idea, but I think you've got a dodgy kit there. MAy be worht seeing if you can return it?
Biddle
Post by Biddle »
Looking at it the passenger has dropped the same amount now. I aint been drving it the last few days so its rubbing the passenger side too now. I ordered coils today so Il be taking these off and selling them. Problem solved :lol:
Tim_GTi
Post Whore
Post by Tim_GTi »
Id recommend trying to return the 40mm kit, there's clearly a fault there
mk4mike
Post by mk4mike »
there is a way you can do your camber your self but its up to you if you wanted to i have drawn a pic to show you what i mean
hope this helps
ps don't drill to close to the edge tho you only want 2/3mm
Bepe
Post by Bepe »
woah, dont drill owt, juust undo them to bolts and pull the strut out, i did it and went and got the camber checked, was spot on ;)
mk4mike
Post by mk4mike »
it all depends on if you have enough movment on the suspention to do that really
Tim_GTi
Post Whore
Post by Tim_GTi »
wouldn't that be really bad for the car? A bent strut but straight wheel? Surely something would brake
Bepe
Post by Bepe »
what you mean tim? when you pull the strut out, the wheel comes with it
