I managed not to bend anythin except the wishbone, I took the wheel off and I can see the wishbone and it's all bent up. I looked in the haynes manual, its held by 3 bolts by the ball joint and 2 bolts closer to the engine.
I need advice on taking it off, the 3 bolts by the balljoint are on a "13" wrench and the other two are on a "17" but they are on extremely tight.
Any advice on how to unbolt/untighten the heavily tightened bolts. Also I damaged one of the bolts on the "13"wrench when it slipped, any advice on how to get it out?
Any advice on the change would be great.
Thanks for any advice in advance.
