samil87
Posts: 440 Joined: Tue Jul 04, 2006 1:23 pm
Post
by samil87 » Tue Mar 18, 2008 1:04 pm
looking to get some new bulbs off powerbulbs.co.uk...
do uk-polo members still get discount???
if so wot is the code???
and any recomendations??
samil87
Post
by samil87 » Wed Mar 19, 2008 7:29 pm
thanx mate!!
samil87
Post
by samil87 » Fri Mar 21, 2008 6:43 pm
managed to fit the sidelights no problem!!!
then came fitting the h7s....put the bulb in switchd the light on and could just hear a buzzing type noise and there was no light
tested the bulbs on the other headlight and they work fine!!!
checked the fuses and they are all fine....any ideas???
Posts: 14873 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Fri Mar 21, 2008 6:56 pm
ensure all the wiring is tight. Where is this buzzing coming from?
samil87
Post
by samil87 » Fri Mar 21, 2008 7:02 pm
it came from the headlight for bout 10 seconds then disapeard...wiring is all fine...the headlights are less than a year old...fitted professionaly!!!
Post
by alexperkins » Fri Mar 21, 2008 7:41 pm
What headlights have you got then...im assuming non factory?
samil87
Post
by samil87 » Fri Mar 21, 2008 7:43 pm
they are completely standard...just new cos i had them replaced due to a crack
Post
by alexperkins » Fri Mar 21, 2008 7:53 pm
How odd. Check the bulb hasnt blown/is faulty. There shouldnt be any noise from the headlight, unless your motor is playing up.
samil87
Post
by samil87 » Fri Mar 21, 2008 8:03 pm
bulbs are fine as i tested them in the other headlight
Post
by alexperkins » Fri Mar 21, 2008 8:04 pm
Ill do some research and get back to you bud
samil87
Post
by samil87 » Fri Mar 21, 2008 8:13 pm
lol...thanx for that mate
