recently ive been getting the epc and check lights coming on on my polo. it started as a intermittant problem (once every couple months - would usually go away the next time i start the car)
however recenetly it has been coming on virtually all the time. its been like this for the past few months,. i havent noticed any difference with the driving of the car and itseems to be running fine. sometime the light may not come on but generally about 85% of the time it will.
i was under the impression it was the lambda but not sure about it. can anyone confirm what the fault is from the log below
Address 17 -------------------------------------------------------
Controller: 6N0 920 904 D
Component: KOMBIINSTRUMENT BOO V10
Coding: 00441
Shop #: WSC 00788
1 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
any help is much appreciated.
Vagcom help
thanks lads,
anyway have managed to re-scan with vagcom again setting it to 9600. this is the result
Address 01 -------------------------------------------------------
Controller: 036 906 034 D
Component: MARELLI 4LV 3458
Coding: 00031
Shop #: WSC 00739
3 Faults Found:
17566 - Manifold Pressure Sensor (G71): Implausible Signal
P1158 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
Readiness: 0000 0000
can anyone shed some light into this? been driving around now for 3-4 months with both the engine check & EPC light both on and havent noticed any major problems - drives as normal - although it does feel a bit slow (even for a 1.4 ). how serious is it?
Coding: 00031
Shop #: WSC 00739
3 Faults Found:
The top one is obviously a map sensor fault, are you running an induction kit? This may cause that code to come up. The immobilizer one just means it failed to start at some point. The bottom one suggests the car has been drivin with the speedo unplugged at some point. I'd clear all codes, leave it a week and read them again. The epc light usually comes on when a brake light bulb has gone. Worst case is all the brake lights are out which suggests brake light switch.
