Changing 256-312mm
Polooo
Changing 256-312mm
Post by Polooo »
Hello!
I'm new here so...hello
I have searched whole Google and i came up with O...
I have polo 9n tdi 74 kw(ATD) and I'm planing to change the original brakes with 312x25...i've alreaady bougt the brake sistem form S3 but the problem is that calipers cannot be mounted on original "swing arm...Has any1 done this , because i heard that older polos have simililar "construction...for any kind of information i will be grateful cool.gif 8) 8)
Tim_GTi
Post Whore
Post by Tim_GTi »
Never heard of an S3 convo on a 6N2, so not quite so sure what it will take to get them on there (I'm sure it feasible).
A popular mod however is the 280mm upgrade usually from the G60, which use the OEM calipers (just different carriers).
Polooo
Post by Polooo »
it's 9n(2OO2)...ask i can tell discs fit perfectly, the problem is the way that calipers are attached ...i can take also 28O but im not sure it will be enough for 23OBhp+
DanDiesel
Sponsor
Post by DanDiesel »
as its a 9n mate, your better off putting it in the 9n forum or mk6. i'm someone in there will be able to help ya dude!
Tim_GTi
Post Whore
Post by Tim_GTi »
Ah yeh sorry mate I thought you referring to a 6N2 (mark5), try the mark6 section 8)
Polooo
Post by Polooo »
sorry...
