bbs rm????
bbs rm????
got a set of rm's the other day, 15 x 7. can anybody tell me what the offset is most likely 2 be and also what it will change to if i put a 2 - 2.5" lip on. thanks.
- Tim_GTi
- Post Whore
Ah man it's talk like this which worries me!!! you had 205s on them tho didnt you Neil?sorted wrote:Mine are 8" and are ET12.
I have just split my 8" wheels and about to do a swap for 1" lips to make them 7" (if you posted earlier - or if the deal goes through i can do a straight swap) and the back will be the old front 7.5" as the rubbing was UNREAL even after arch work...
Yes, then i put my 7.5" with 195 on the back and its still rubbing lolTim_GTi wrote:Ah man it's talk like this which worries me!!! you had 205s on them tho didnt you Neil?sorted wrote:Mine are 8" and are ET12.
- Tim_GTi
- Post Whore
lol, mine aint gunna stand a chance then with 8" 195/45s all round when it gets slammed to the floorsorted wrote:Yes, then i put my 7.5" with 195 on the back and its still rubbing lolTim_GTi wrote:Ah man it's talk like this which worries me!!! you had 205s on them tho didnt you Neil?sorted wrote:Mine are 8" and are ET12.
My rubbing was unreal with my RM's
I had 7.5 at the front and 8's at the backand rubbed sooooooooo much! I could barely take anyone in the back and the front had created a new groove in the tyre !
That was without arch work though! Would scrub on every bump and corner lol
If i were to go for 8's again, i would go for ditchfinder 185/45 tyres and i think then you'd be safe! either that or get stupidly hard suspension with no rebound!
I was sitting at this height! Low.....and unbearable! but i still stuck with it haha, cos it looked good
![Image](http://i45.photobucket.com/albums/f59/Philwatson/The%20polo%20show%20o7/351.jpg)
looking at that makes me realise how low i actually was at the front
Low daily drivers rule!
![Image](http://i45.photobucket.com/albums/f59/Philwatson/The%20polo%20show%20o7/352.jpg)
![Mad :x](./images/smilies/icon_mad.gif)
![Shocked :shock:](./images/smilies/icon_eek.gif)
![Razz :P](./images/smilies/icon_razz.gif)
![Very Happy :D](./images/smilies/icon_biggrin.gif)
In all fairness tim, i'm not overly knowledgeable when it comes to camber shims, i just know that you can buy a set degree to give your wheels more og a negative camber, so you retain the width but the top of the wheels stick in the arches slightly more
will help eliminate rubbing, but i would imagine you would get inner wear on your tyres alot quicker.
I'm keen for 10's on the back of my car, but i would defintely be going for camber shims, or it will rub! even with the pulled arches
![Smile :)](./images/smilies/icon_smile.gif)
