[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 LED headlights - UK-POLOS.NET - THE VW Polo Forum
you may have noticed on new audis they have led headlights
i thought this would look pretty cool on my car and have seen a few drive by with them. you can buy them from ebay for about £30.
just wondering how do i open my headlamps up to put them inside cuz i dont want it on the grille
I believe that if you take your headlights off the car and stick them in the oven for a bit, it will heat up the glue and then you can disassemble them to fit the LEDs inside.
Might be worth seeing how much a set of headlights are from a local scrappy or a breaker (or eBay) so that you can play around with the spare set whilst keeping your own headlights on the car?
You need to take the headlight out to pop the glass off. The headlights fairly easy to take out, on the 6n its just held down by a few screws, easiest way was take it out with indicator then slide indicator out. I'd imagine its the same for the 6n2.
As for the glass I member you could take it out somehow, think there was a slight small metal clip on the side of the headlight (the side the indicator was) that you undid and popped the glass out or you could easily detach the reflective stuff from the headlight casing, once you get the headlight out you should see it very simply.
