brake pad choice?
rolo
brake pad choice?
Post by rolo »
Hi All,
Can some one suggest or recommend some front brake pads which are a little more fade resistant than standard and which do not require too much extra pedal pressure. the car is a 1.4 8v 6n2 fitted with Brembo smooth discs.
I have been using Black diamond pads which need a lot of extra pressure to work.
Rolo
Si_GTi
Moderator
Post by Si_GTi »
I've been using Black Diamond Predator pads for over two and a half years now and don't think that they require any extra pressure to work :?
When was the last time you had the brake fluid changed?
Cheers :)
rolo
Post by rolo »
Si_GTi wrote:I've been using Black Diamond Predator pads for over two and a half years now and don't think that they require any extra pressure to work :?
Cheers :)
Hi SiGTi, Thank you for your reply. I changed the fluid Dot 5.1 last summer when I fitted the discs, pads, and braided hoses.
It is strange that you have not found extra pedal pressure necessary as I have.
Rolo
