17x7.5 wheels with 215/45 OR 205/40 tyres?? help
Im looking to buy some old style rs4 wheels and lower my 9n 60/65 on FK highsports. These wheels are 17x7.5 and come with 215/45 tyres but looking through similar forums people seem to suggest 205/40's. Is it possible to get 205/40's on 17x7.5 wheels?
205/40 is the industry standard size tyre to fit on a 17x7.5" rim
So no they wont be stretched.
By industry standard I mean that if you buy a wheel and tyre package from a shop a 17x7.5" rim will come with a 205/40 tyre 99% of the time
Have a look on a tyre manufacturers website (toyo or yoko) and look for the tech specs section. It will usually have a column for what widths a particular tyre can be fitted to. For a 205/40 its usually between 7" and 8". Thats what the tyre will be 'rated' to go on however some people (myself included
) have ignored those 'recommendations' from time to time
Stretched tyres are usually used to avoid rubbing/to look good. They will not improve your handling or ride in any way though, theyll ruin it!
If you really wanted a slight stretch on a 17x7.5" rim go for Continental Sport Contact's (think they are SC2's) in a 195/40/17 flavour. Will look good if your going to slam it and will at least retain some 'give' in the sidewalls
Ive got 17x7.5" alloys with 205/40's on and my coilovers are as low as they will go (ive also removed the adjuster plates from the rear's to drop it a wee bit more). It rubs but I can live with it
Pics: (because im a shameless pic whore!)
Hope that helps
Hope that helps
- TimGti
- Drives: 9n3 1.9 Tdi Sport
pidge87 wrote:205/40 is the industry standard size tyre to fit on a 17x7.5" rim
I disagree im afraid. It depends a lot on the make of tyre you fit. I had yoko a539 205/40 on a 7.5 and it gave a slight stretch. Now I have falken rubber and the stretch is much more obvious.
I think that 205 is fitted to a 7" rim if you want no stretch at all. My comps are 7.5 and there is quite a bit of stretch, the lips of the rims stick out quite a bit from the tyres.
Cars lookin good btw Pidge
david burton
david burton
david burton
