Wheel + tyre weights
Posted: Fri May 09, 2008 9:40 am
Out of idle interest, I weighed my TT alloy + tyre and came up with this:
17.6kg: TT alloy + 100% worn 205x40x17 BF GoodRich tyre
21.1kg: TT alloy + 0% worn 205x40x17 Yoko Parada tyre
With new Yoko Paradas this came out as a surprising result!
I couldn't believe the extra weight. But a rough calc of 8mm tread depth gives 3kg extra per tyre (if tyre rubber is roughly the same density as water).
Will be weighing the steel and 15" alloy tomorrow.
