6N2 Capacities
mickeyreay
6N2 Capacities
Post by mickeyreay »
Hi All
Servicing our newest runaround for the missus. Can anyone tell me the capacities for the 1.0MPi yr 2000 6N2
Oil with Filter change?
Antifreeze change?
Are the standard VW sparkplugs already set to the correct gap?
Thanks in advance.
polo2k
Post by polo2k »
On the 1.4 the oil is 4.2L and about 5L of coolant
as forthe plugs they should be right but you can check them any way. the deal;er will be able to advise of the gap
Speedlaw
Moderator
Post by Speedlaw »
The 1.0 engine needs 5,6 liters of antifreeze/coolant. It's the Red G12 spec stuff.
The ALL or ALD 1.0 needs 3,2 liters of oil. Always check the level after filling (obviously).
The ALD has NGK PZFR 5D-11 plugs which require a distance of 1,0 - 1,1 mm.
The ALL has either BERU (14 GH-7 DTUR) or NGK (BUR 6 ET) plugs, with a distance of 0,7 - 0,9 mm.
All plugs require a torque of 25nm.
(Only know the Metric sizes, sorry)
