Key/Remotes
Posted: Fri May 16, 2008 3:11 pm
by Torq-Al
Went & looked at a ’96 mk4 Polo, which is really tidy & extremely clean. Documented low mileage, main dealer history until recently, local reg etc.
One slight downer is it only has one key/remote, how easy is it to get a replacement, main stealer job or can I get a blank, have it cut & then program it at the stealers or via VAG-COM myself ?
Posted: Fri May 16, 2008 5:02 pm
by polo-sib
A new blank key and cut would cost you around £5-10, but the key would not contain an immobilizer chip.
So best thing to do is find a blank key with an immobilizer chip, good places for this would be ebay. Once you got a blank key with immobilizer chip you will need to get it cut, this will cost you no more than £5. The next bit is expensive, the programming of the immobilizer chip would cost somewhere between £52-82 (the price is dependent on whether you know the 5 digit code to the car) if the security code is not known then go dealership. Expect to pay around £82, also you will require all documents to the car and personal details as well as the car needs to be bought down when getting the key programmed.
Posted: Fri May 16, 2008 11:28 pm
by NOZ
The one with the chip is a 'transponder key' I believe. I had a second key made from the single one I had which cost £35 to get it programmed and cut.
Posted: Sat May 17, 2008 5:36 pm
by Torq-Al
NOZ wrote:The one with the chip is a 'transponder key' I believe. I had a second key made from the single one I had which cost £35 to get it programmed and cut.
Where did you go to have it programmed, as i don't want to spend the 'stealers' the money if i can help it
Posted: Sat May 17, 2008 6:25 pm
by NOZ
well I got it done in Leytonstone from a key cutters. Depends where you live at the end of the day!
Posted: Sat May 17, 2008 9:15 pm
by solidsponge
I got one for £20. Small electrical car shops are cheapest I guess.
