jus got a mk4 polo and havin trouble with overheatin
my fan wasnt workin but changed the little sensor in the radiator and that works a treat now but im still overheatin
the bottom hose is red hot and the top hose is stone cold and reading up on the forum is sounds like it could be the thermostat
but i dont know where it is lol so could someone please tell me (a picture would be a great help)
im not a mechanic but got a polo :D "thermo"
dragon_green
Re: im not a mechanic but got a polo :D "thermo"
No you didn't, that's a Mk5.adummy wrote:jus got a mk4 polo and havin trouble with overheatin
Yes it's deffo a dodgy thermostat - no doubt shut in 'closed' position as per your description. It is situated on the left hand end of the cylinder head. As well as a new 'stat, you'll need a new sealing ring. Torque setting for the 2 bolts are 7lbs. Make sure you insert 'stat the correct way round when refitting. HTH.
By the way, what colour green is that? I quite like it; you don't see many in that shade.
