borbet A's on 6n2
rick
borbet A's on 6n2
Post by rick »
just wanted 2 know whether a set of borbet a's 16's, 9 in the back and 7.5 in the front will fit on ma 2000 reg 6n2????
Tim_GTi
Post Whore
Post by Tim_GTi »
Might want to try posting this in the markV section mate, 6N2 = markV 8) .
Short answer - No. 16X9 is a bit ambitious on a 6N2 without serious arh work
rick
Post by rick »
do you think the biggest i can go is 15x9 without =any arch work??
Tim_GTi
Post Whore
Post by Tim_GTi »
It really depends on what offset they are and what size tyres you run.
What ride height are you planning on running?
I believe 15X8 is the largest you can go without any arch work.
That is what I currently ride, with an offset of 25. I get no hassle what so ever, but I ride standard height and stretched tyres. When I get the stance I want on my car I know I'll get scrubbing left right and centre.
rick
Post by rick »
whats the largest of set which requires no work to be done?
Tim_GTi
Post Whore
Post by Tim_GTi »
What ride height are you currently sitting on?
rick
Post by rick »
standard
Tim_GTi
Post Whore
Post by Tim_GTi »
You can run 15X8 offset 25 with 195/45s tyres no problem.
You could probably run 8.5s with the same tyres and offset also though.
rick
Post by rick »
cheers
