Any ideas what will go onto the front of a 9N 1.2 (65) fairly easily and how do we convert the rear to discs?
1.2 SE brake upgrade?
We'll be needing bigger brakes all round soon
I'm busy doing mine atm. I've gone for the golf gti turbo brakes (coz i knew a lad breaking a mk4 turbo and I could get them at a decent price!)
Rears are relatively easy, by this i mean you don't have to change the rear beam, the mounting points for the caliper are already there... so.... you'll need caliper, carrier, stub axle and probably a different handbrake cable.
Fronts are a bit more of a pain, you'll need polo gti (mk7) or polo GT TDI hubs bearings and bearing carriers (yep, thats the big bit that the shocker sits in too!)
all in all, not a cheap or easy job.
