6n2 1.0 spark plugs
xcore
6n2 1.0 spark plugs
Post by xcore »
going to get a set of spark plugs tomorow, which fitment do i require?
would have a check myself bu tthe covers being a b***h and wont come off
Halfords have a big list which you can reference two. Its 4 plugs you need. Get Bosch or NGK as these tend to perform better than the cheaper brands.
jonnopolo
Post by jonnopolo »
would have a check myself bu tthe covers being a ***** and wont come off
The cover can be a pain to remove, but once you've removed the 2 bolts, it's then just being held by 2 plastic pieces at the back that go into rubber grommets. You just have to keep pulling (hard). Next time I take mine off, I'm going to spray rubber silicone spray on them to make it easier to remove in future. There's also 2 (I think) hoses to disconnect.
As Alex says, use Bosch or NGK plugs; I have NGK in mine (Platinum PZFR5D-11); mine's a 1.4. Check the reference booklet in Halfords for the ones you need.
xcore
Post by xcore »
sorted, bosch ones were to big so got some nkgs, 40 quid for four!
still not sorted my rough idle on cold start, will have to replace the temp sensor next month and see if that sorts it
