[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Idle Problem? read this. - UK-POLOS.NET - THE VW Polo Forum
hey as ive been on here ive heard tht theres been a good few polos tht have idling problems, just thought id add to the things to do to try stop this... i recently got really annoyed by it so i clean the distributor and cleaned the plugs, and also which i found was the breather for the airfilter was clogged with gunge (similar to head gasket gunge) i therefore cleaned this aswell and now the polo idles perfectly, nice and smooth, just thought id share tht if it helps even a few people out
hope its some help lol
As everyone knows i've practically replaced everything associated with the issue! Changed the Temp Sender 3 weeks ago and its slightly worse then the original one. So now all I have left is the idle control valve to change. A new one costs about £300 si i'm on the look out for a scrappy.
lol yea ive read somewhere you basicly ried everything... hope this works... it help mine idle, and it stayed at peace, better then when i even bought it, but yea good luck with this and tell me f it works, would love to kno and if it dont then good luck with the search NOZ
GSF lists them for £76 - bit more reasonable! www.gsfcarparts.com - very useful people
Hey guys, ive got a w reg gti and it was idling really badly-up and down everywhere and seemed to be struggling alot.
I read this post last night and thought i'd try it to see if it made any improvements....couldn't be better!! I took the breather pipe off the air filter and took the airbox off. The pipe that runs along the top inside the airbox was full of gunge and oil so i cleanded it all out and put a new air filter in it. Its running so much better already!Thanks
My 6n2 was a nightmare for idling. From what I recall any number of things case it. I just began to ignore mine, it only stopped when I had a new exhaust, temp sensor, and lamda so it was probably one of those!
