ive got a polo sport and i want to remove all the calipers to paint them, i need to change the fluid any way as i dont think its been done yet, how should i go about doing it?
thanks, James
removing calipers
jamesthomas404
Personnaly I'd treat these as two jobs, to change the fluid you just flush the old through with new fluid - maybe using a vac system - Myti-vac or the Gunson pressure bleeder. Normally 1.0>2.0 (or maybe only 0.5>1.0) litres is enough bleed short runs then longer runs. To paint the calipers, I'd clean them up as much as possible and locate them near where they should be mounted in a way to avoid stressing the flexi pipes - and paint them - maybe use stiff wire through a bolt hole and hang them from a convenient point.
jamesthomas404
thanks for the reply
would it do any damage if i left the braking system with no fluid in while i removed and painted the calipers then filled it back up again once id fitted all the calipers
jamesthomas404
ok thanks
ill just do that then. cheers for your help!
david burton
