My Polo 9N 1.4 Tdi has started to flash its orange coil light at me. I did some reading and found out about the brake sensor problem, and that it could be causing it.
So i checked the brake lights and all would appear fine
Is it possible that it could still be an issue with this sensor, even though it seams to be working normally? Or is it likely to be something more sinister
I don't have VAG COM so I can't check the error codes myself.
Mark
