when i have my sub on after a while it cuts out, then comes back on.
as if the battery had died and once got a bit of charge started again, does this all ttime.
i'm sure its not the battery as half an hour with it on whilst driving youldn't drain it.
Where have you it earthed to?it can cut out all of a sudden if its not earthed properly. if its on the seatbelt bolt it has to be clamped in tight and the bolt has to be clean and i sanded mine down a bit
I had this problem before too, it turned out to be the amp. My guess would be a short inside the amp itself which produces an over current, then the amp justs cuts itself out to save itself. It just happened from time to time but its whileeee annoying! I would suggest buyin a cheap second hand amp at around the same rms and just swap them over.
