Sorry for the Noobishness of this question. If this were the mk4 forum id be king offall things knowledge damnit, move into turbos and fancyness and im screwed lol.
LIMP MODE....?
LIMP MODE....?
ive jst been reading thetopics as i do off a morning and everyone seems to be talking about this limp mode thing... what the devil is it? Im guessins its like a safety mode for when the car thinks something is wrong?
- KennyPOLO_Gti
Limp Mode – These cars are designed to protect themselves from engine damage. If the engine boosts too much, or the engine does not get enough fuel it will go into a limp mode where boost is limited to protect the engine. It limits boost by controlling a solenoid on the wastegate line (N75), by closing the electronic throttle or by opening the DV valve. If you are experiencing a limp mode the best thing to do is get the car scanned for codes and to see what is wrong. Look at fuel trims for signs of running lean, and to look for MAF problems, or O2 sensor problems. To look for potential boost problems log Block 115 and you can see the specified Vs actual boost. If you exceed the specified then there is a good chance that you will go into this limp mode. Stock specified is a max of 14 psi for a 2002+ car.
- KennyPOLO_Gti
- KennyPOLO_Gti
