The 9n Stance thread!!
Alright, for future reference of all 9n owners this should be useful. Post a few pics of your car, then tell us the suspension, the wheels (size + width), the offset, tyre size and any arch mods.
Should be interesting to see how much girth you can fit on a 9n as I reckon they should be able to take a bit. 9's anyone?
My stance(s)
All photos on FK Silverline coilies wound all the way down with removed front ARB and removed rear spring adjusters
1. 16x8 et25 Compomotive TH Mono on 205/40/16 Avon ZZ3's
2. 17x8.5 & 17x9.5 et~53 Eta Beta Turbo Twists with 205/40 front and 223/35 rear (sttttretch much )
3. 17x7.5 et35 BBS LM Reps on 205/40/17 Falken FK452's
4. 17x8 BBS LM Reps with the same 205/40 Falken's that were on the 7.5's
No photos as yet but will get some at some point
heres mine running 17x8 et26 17x9 et34 rear schmidt th lines on fk konigsport coilovers wound all the way down
runnig koni springs and shockers in this pic 50mm
Only a couple others but none showing the proper poke that was going on
That was 25mm rear adapters and 30mm front. Rears stuck out 30mm from the arches
And about arch work unless your planning on flaring/pulling the arches there is no work that can be done! But to fit those splits youd probably need to pull your arches about 10mm to get the tread completely under the arch
- whitegtipolo
