Has anyone got a picture installed of one of these, I am planning to buy one and it baffles me as on ebay when you look at it, you cannot see where the lambda goes, also will it be linked to the bendy joint or will it stretch and bend straight right back into the cat?
Any advise on manifolds would be appreciated.
Alex
4-2-1 Manifold question
JarnoVWPolo6N
okayy. hers a few pictures of myn for ya to try and explain where it goess...
this is what they look like. bearing in mind it was chrome..
this is. if you look at the top of the mage above. it goes down the back of the enginee, and in the middle of the picture you can just see the lambda switch. and you can see how far the cable has strettchd.
this is from undernear the car. where the manifold joins the the other piping, you can see the switch sticking out to the left.
hope it helps. if not im also selling my manifold in about 3 days and ill give you my switch and connection. so all you gota do is unplugg your old one and plugg this one in. andd it has passed the MOT with it on
im selling the whole stainlesss steel too if your inteersted.
£100 for the maifold.
£180 for the whole lot.
£100 for just the stainless/center section and back box.
all pass MOT as it passed on mine 2 weeks ago.
