oil in air box!!!!!
simon pope
oil in air box!!!!!
Post by simon pope »
right its pissing me off now!! i keep getting gunky oil in the air box through the breather ( the bit with the rubber seal) now the oil that comes out is gunky and of a creamy colour?? ive checked the oil on the dip stick and i cant see any droplets of water, but when i remove the oil cap off the rocker cover there is a slight dis-colouration in the oil there but only slightly?? any ideas could it be the gaskets??? im not losing any water or oil????? puzzled to say the least?????? :roll: :cry: :cry: :?: :?: :? :?
optima21
Sponsor
Post by optima21 »
if you're only doing short journeys its because the engine isnt heating up properly and its not a problem, its just condensation in the crankscase as a result of the result of the piston blowby gasses. If you take your car on a long and hard run it should clear up.
So its just normal and nothing to worry about
simon pope
oh i see, i have asked in my local garage and he said the same i just didnt want the oil to fall into the throttle body thats all.
cheers
amstrange1
Post by amstrange1 »
The oil and crap in the breather pipes is designed to go in to the throttle body and be burnt off for environmental reasons. If it's breathing a lot of oily crap through those pipes it's worth taking the breather system apart and giving it a good clean out before it gets horribly blocked.
My old CL engine used to breathe heavily, so I cleaned the breather pod etc. out and then vented the breather pipes to an old bike-bottle as a catch tank. The car ran a lot better after that and it stopped the breather getting so clogged.
As Dom said the mayo like gunk is due to the engine not getting a chance to get properly hot - but the yellowy orange crap is quite normal in the breather system. Just out of interest I noticed my mum's Mk4 Polo had a lot of mayo under the filler cap recently, which puzzled me because I'd be using it a fair bit. The warm air feed was partially disconnected (anything to do with its recent service at VW? :roll: ) - so it was taking longer to warm up, thus the mayo. Hooked it back up, took it for a 'spirited' 10 mile run and the mayo was gone.
Tahrey1043
Post by Tahrey1043 »
hopefully im right on this but you could just take the whole damn thing off and probably not have too many problems... maybe a bit (tiny) of oil spatter in the engine bay and having to top up with 525ml instead of 500ml...
if im wrong (seriously so, anyway) someone tell me as i should get mine replaced in that case :)
