either way it cant good so somethings on the cards
if so would i be able to get it done on warranty? its done just over 70
cheers
snibs
sorry tim, meant just over 70,000 miles,Tim_GTi wrote:Just done over 70 what?
If it was the pedal box, you'd feel a creak in the clutch as you depressed it. A generally harsh or scatty feeling clutch will relate to the clutch itself or the cable more likely.
Has it had a clutch change before? If so when, if not what's your milage?
cheers mate, brilliant helpTim_GTi wrote:70k is an awful lot for a clutch, (What engine du have?) If it's not that I'd seriously consider one, (For the GTi) GSF do a SACHs clutch kit for under £90 delivered - Quality price. If not GTi, then I think the options are broader and cheaper, not 100% sure though.
Anyway as I said it's likely to be cable related also. Best bet is to take it down to the a garage and get them to check the pedal box weld (Just has to poke a torch up into the driver's footwell), and have a feel of the clutch. It probably will need replacing but they will be able to confirm.
Then just purchase a clutch cable direct from VW (cost less than £30) and tell the garage to put that in whilst they're at it if needed. If not you can always return it at no charge (clutch cable is classed as a non specific/special order part, so will require no handling charge if returned).
Hope this helps.
