think its pedal box time?
Posted: Sun Sep 21, 2008 8:43 pm
by sniblett15
recently my clutch feels like a scarletrix controller ( think thats how you spell it?
) only just started happening so should be k for a bit but wondered if it is my pedal box or just clutch?
either way it cant good so somethings on the cards
if so would i be able to get it done on warranty? its done just over 70
cheers
snibs
Posted: Sun Sep 21, 2008 9:25 pm
by Tim_GTi
Just done over 70 what?
If it was the pedal box, you'd feel a creak in the clutch as you depressed it. A generally harsh or scatty feeling clutch will relate to the clutch itself or the cable more likely.
Has it had a clutch change before? If so when, if not what's your milage?
Posted: Sun Sep 21, 2008 10:07 pm
by Andy1.6
My clutch sounds like a barn door when you push the pedal down so pretty sure its the pedal box thats screwed, too skint at the moment to repair it though so I'm driving with my fingers crossed! Hoping it holds out til I go traveling!
Posted: Sun Sep 21, 2008 10:33 pm
by Tim_GTi
Pedal boxes have a tendency to weaken and just snap, if yours is creaking I'd get it checked out A.S.A.P, it can cause a whole world of pain. All they need is a reinforced weld.
Posted: Mon Sep 22, 2008 6:46 pm
by sniblett15
Tim_GTi wrote:Just done over 70 what?
sorry tim, meant just over 70,000 miles,
it hasnt had a clutch yet either
Posted: Mon Sep 22, 2008 7:56 pm
by Tim_GTi
70k is an awful lot for a clutch, (What engine du have?) If it's not that I'd seriously consider one, (For the GTi) GSF do a SACHs clutch kit for under £90 delivered - Quality price. If not GTi, then I think the options are broader and cheaper, not 100% sure though.
Anyway as I said it's likely to be cable related also. Best bet is to take it down to the a garage and get them to check the pedal box weld (Just has to poke a torch up into the driver's footwell), and have a feel of the clutch. It probably will need replacing but they will be able to confirm.
Then just purchase a clutch cable direct from VW (cost less than £30) and tell the garage to put that in whilst they're at it if needed. If not you can always return it at no charge (clutch cable is classed as a non specific/special order part, so will require no handling charge if returned).
Hope this helps.
Posted: Tue Sep 23, 2008 8:09 pm
by sniblett15
Tim_GTi wrote:70k is an awful lot for a clutch, (What engine du have?) If it's not that I'd seriously consider one, (For the GTi) GSF do a SACHs clutch kit for under £90 delivered - Quality price. If not GTi, then I think the options are broader and cheaper, not 100% sure though.
Hope this helps.
cheers mate, brilliant help
gotta go down there to get me brakes fitted anyway! ( not quite confident enough yet ), so get them to have a look at it then!!
its a 1.4 mpi btw, you reckon the clutch would need doing soon then?
thanks again mate
Posted: Wed Sep 24, 2008 1:21 am
by Tim_GTi
Yeh mate, just over 70k on a 7 year old odd car, the clutch will probably need replacing.
