How do you know how much your lowered by?
Posted: Mon Sep 29, 2008 1:32 pm
by yosin
Ok, maybe a noobish question but like how do you know how much your lowered by?..ive got a set of adjustable coilies on the polo and im just going to tinker with it in a moment. But was wondering how do you know much your lowered by? is there a gauge or something on the suspension or like you measure it from the ground?
:? thanks :lol:
Posted: Tue Sep 30, 2008 11:07 pm
by Tim_GTi
Measure the height between the floor and the top of the arch before and after you lower. The difference is how much lwoer it is.
Posted: Wed Oct 01, 2008 3:55 pm
by yosin
o i c...so the polo is lowered 15mm? as standard isnt it. so if i was to lower it i would have to add on that extra 15mm that correct.
Posted: Wed Oct 01, 2008 6:00 pm
by Tim_GTi
Eh? The GTi is approximately 15mm lower than a standard 6N2.
Let me determine your situation, is your car standard height or is your car lowered already?
If it's standard and you are planning to lower it. You can work out how low it is after you have finished, by using the method explained above.
If it's already lowered it's hard to determine it. I guess you find a standard GTi a compare heights.
