9N TDi Sport
macp
9N TDi Sport
Post by macp »
Our 2002 polo TDi 100bhp sport has a shake from the steering wheel under braking.There is a good lip on the front discs and I have presumed it needs both discs and pads.Assuming I am correct about this can a novice mechanic like myself replace them and will I require any special tools ?
david burton
Post by david burton »
Front discs are pretty straightforward for a DIY mechanic, no special tools needed!
pip_polo
Post by pip_polo »
sorry to hijack, but is there a minimum requirement for the size of the discs? i think there 22mm and mine are more like 19/20mm.
K.I.T.T.
Drives: Bicycle
Post by K.I.T.T. »
For the front disks, minimum thickness is 19mm according to my MOT report.
Ash :)
macp
Post by macp »
david burton wrote:Front discs are pretty straightforward for a DIY mechanic, no special tools needed!
Thanks David do you know what size discs and pad type I need.Sorry for being lazy I guess I can find this info if I do a search in here.
macp
Post by macp »
Sorry to revisit this thread but can anyone tell me what standard size discs and pads I will need for my 52 plate Polo 1.9 TDi Sport.And will I need a Torx or spline drive etc to get the caliper off ?
Many thanks
