ranson90
Posts: 175 Joined: Fri Sep 19, 2008 7:21 pm
Post
by ranson90 » Tue Nov 18, 2008 6:38 pm
Does anyone know where you can take wires from under the hood into the dash?
I need to run wires from batter into the car
and at the moment there hidden above the wheel and around the door and under (its complicated of how i've done it)
but mainly does anyone know how where (could you do it for me im lazy) to run wires through?
Posts: 14873 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Tue Nov 18, 2008 6:44 pm
Just tap into the main wiring under the relays and fuses, and ground it to the chassis. Much less work!
ranson90
Post
by ranson90 » Tue Nov 18, 2008 6:51 pm
ahh yes but not if i want a light under my hood.
may look into your suggestion for something else as cigerret lighter has broke so cba to fix it or take the wiring from that
Post
by alexperkins » Tue Nov 18, 2008 6:53 pm
What exactly are you wiring up and where?
ranson90
Post
by ranson90 » Tue Nov 18, 2008 8:25 pm
light under bonnet.
with a switch to dash
electronics annoys me
even tho im training to become an electrician
Post
by alexperkins » Tue Nov 18, 2008 8:37 pm
I see. Id draw power from in the car, then come out through the loom grommet on the right hand side behind the brake controller
ranson90
Post
by ranson90 » Tue Nov 18, 2008 9:26 pm
loom grommet behind brake?
i'll have a look for it.
i might have to find someone to do this for me if it gets too hard hahaha
Dink
Posts: 1144 Joined: Fri Sep 28, 2007 9:04 am
Drives: 2015 GTI
Post
by Dink » Tue Nov 18, 2008 10:57 pm
why do you need a switch on the dash?
Tim_GTi
Post Whore
Posts: 12289 Joined: Mon Jun 25, 2007 6:31 pm
Post
by Tim_GTi » Wed Nov 19, 2008 1:26 pm
Dink wrote: why do you need a switch on the dash?
My thoughts too, wouldn't it be better to have a switch under the bonnet?
Tim_GTi on Sun Nov 23, 2008 12:20 am, edited 1 time in total.
ranson90
Post
by ranson90 » Wed Nov 19, 2008 5:38 pm
your kind of taking things to far sorry
I just want to know where i can take wires too and from outside to the inside of my car under my bonnet.
i'de have the switch somewhere around the driver area probably not even attached on just hidden away somewhere.
