bonnet gromit
Posted: Tue Nov 18, 2008 6:38 pm
by ranson90
Does anyone know where you can take wires from under the hood into the dash?
I need to run wires from batter into the car
and at the moment there hidden above the wheel and around the door and under (its complicated of how i've done it)
but mainly does anyone know how where (could you do it for me im lazy) to run wires through?
Posted: Tue Nov 18, 2008 6:44 pm
by alexperkins
Just tap into the main wiring under the relays and fuses, and ground it to the chassis. Much less work!
Posted: Tue Nov 18, 2008 6:51 pm
by ranson90
ahh yes but not if i want a light under my hood.
may look into your suggestion for something else as cigerret lighter has broke so cba to fix it or take the wiring from that
Posted: Tue Nov 18, 2008 6:53 pm
by alexperkins
What exactly are you wiring up and where?
Posted: Tue Nov 18, 2008 8:25 pm
by ranson90
light under bonnet.
with a switch to dash
electronics annoys me
even tho im training to become an electrician
Posted: Tue Nov 18, 2008 8:37 pm
by alexperkins
I see. Id draw power from in the car, then come out through the loom grommet on the right hand side behind the brake controller
Posted: Tue Nov 18, 2008 9:26 pm
by ranson90
loom grommet behind brake?
i'll have a look for it.
i might have to find someone to do this for me if it gets too hard hahaha
Posted: Tue Nov 18, 2008 10:57 pm
by Dink
why do you need a switch on the dash?
Posted: Wed Nov 19, 2008 1:26 pm
by Tim_GTi
Dink wrote:why do you need a switch on the dash?
My thoughts too, wouldn't it be better to have a switch under the bonnet?
Posted: Wed Nov 19, 2008 5:38 pm
by ranson90
your kind of taking things to far sorry
I just want to know where i can take wires too and from outside to the inside of my car under my bonnet.
i'de have the switch somewhere around the driver area probably not even attached on just hidden away somewhere.
