Polo Kangerooing problem
chris_newton
Post by chris_newton »
Hi all i have a 1999 V reg Polo 1.4 CL and it has started to judder / kangeroo when i drive. The thing is it does not do it all the time, i will try and explain what it does.
When you first start it up and its idling, you can sometimes here it, its like its missing a beat and the whole car shudders as if its trying to cut out for a second. when it does this i know its going to kangeroo when i drive it, and it does it in all gears when i press accelerator it judders.
However when i start the car up sometimes its fine and driver perfectly BUT if i am in say the wrong gear and it judders naturally then this seems to start it off and it will do it from then on.
I have had new spark plugs put in it last week and its still the same, my mechanic said it could be the spark plug leads but i had new ones last year so it seems unlikely that this could be the problem.
Anyone have any ideas what could be causing this?
Thanks all
chris
Coil pack maybe. It sounds like a misfire. Maybe try cleaning the throttle body out as it could have something to do with low revs
kipper
Post by kipper »
i had a similar problem to this the other week and i found out 2 of my spark plug leads were loose. once i pushed them in properly and checked them all properly the car worked fine..
could always try checking the leads arnt loose. wont hurt to check.
C4RLMILLICHIP
Post by C4RLMILLICHIP »
Tar because my feels like its starting to do it too
ill have a look weekend now i no what to check
