hi i have an problem with the gearbox it rattle like hell, but when i press down the clutch the sound does away when i leave it back up it comes back again.
it does not happen all the time either.
the gear slots in as the same and it feel fine in every gear.
i have had the car revo'ed but that should not make any difference. should it?
i read some where that its an common fault on the gearbox?, like an rubber gromet has weakend or something, can someone confirm this? or something else?
can someone please help me its bugging my like hell.
thanks all for your help
1.9 Tdi pd100 gearbox
- Sponsor
- Sponsor
the same
Hey jap master i had the same rumor like you but not that noisy. I use the same car as you 1.9tdi 100hp and this started after i kept too much pressed the clutch in some mountain roads, and i felt bad odors coming from the engine. Now it's been like 3 months that i use every day my car and the clutch works fine but i hear this noise....so i think i will go to VW and let them worry for this because i think it will cost... When i send my car to VW the technician said that if the rumor should me more intensive i should check up the gearbox in a more detailed way because he just heard the noise and pressed the clutch to verify it's effectiveness. So if i will find something i will let you know
