Need Some Help, 6n2 Rear Lights On A 6n
C4RLMILLICHIP
Post by C4RLMILLICHIP »
I've put on a set of 6n2 rear lights on my 6n i followed the step by step guide
And the left side work ok but the right side is still not working right
Can some 1 take a photo of there right side of how they wired it in
Polo96CL
Post by Polo96CL »
I can do this for you mate, but its 1am and I don't think my neighbours would appreciate me rumbling around in my car at this time of the day lol! If you still need one I can get some tomorrow morning :)
C4RLMILLICHIP
Thanks mate
If you can just take a photo of the wires going into the block i can just copy it mate thanks
Because when i brake my indicator comes on too
trav
Post by trav »
mate its as simple as this,
on the right connector thing, cut off the to little things that stop it going in backwards. once there off, swap 4 & 5 and then put the connector in BACKWARDS and you'll be fine!
C4RLMILLICHIP
Ok thanks mate ill give it a go now
Polo96CL
Post by Polo96CL »
I'm not sure if you can see this correctly as my camera flash sort of blasted the colours out of the image but you can see the connectors 4 and 5 have been swapped around (red and black, Green and black). You do have the connector in backwards too (shaved off the tab which restricts it).
C4RLMILLICHIP
Cherres lad got it sorted now
Just need to smooth it now
