Coldest Temp Reading In Your Car??
KennyPOLO_Gti
Post by KennyPOLO_Gti »
Got a pic at minus 4.5 this morning, Actually went to minus 5!! FREEEEZIN!! :shock:
brad mole
Post by brad mole »
do all the mk7 polos have the temp gauge or just teh gti, 'cos i dont think mines got it, same with the trip computer thing that tells you your mpg etc.?
pip_polo
Post by pip_polo »
its the trip computer, with buttons on end of the wiper stalk. i've had -3.
Dink
Drives: 2015 GTI
Post by Dink »
i'm yet to see mine below 0 yet
wonder what the output temp of the forge FMIC would be @ 0 degrees
Jeff GTi
Post by Jeff GTi »
@ dink
it would also likely be 0 degrees aty the coolest
its not gonna go below ambient temperature
when mine was ran in the summer, at 23 degrees outside, the output from the front mount was the same, as it was hooked up second time it was 18 degrees, and the output was again as per the ambient outdoor temp
for it to get colder it would have to be a condensing unit like the air con unit is, not an air based cooler
an easy way to work out intake temps when forge front mounted like mine is look at the external temperature, it will be no hotter than this :D
Dink
Drives: 2015 GTI
Post by Dink »
well i know it wouldn't have been cooler :wink: :lol:
i would of put the temp @ about 10 degrees but if it is lower perhaps thats why it doesn't run the same as when it was a bit warmer
Jeff GTi
Post by Jeff GTi »
how do you mean? mine loves the cold breathing, it absolutely flies
Dink
Drives: 2015 GTI
Post by Dink »
sometimes it seems to have a flat spot then it takes off like i put gunpowder in it instead of petrol.
it probably had this before just seems more noticeable now it's got alot colder
i've got the apr stage 1 map.
KennyPOLO_Gti
The APR stage 1 remap does have a loose boost around 2.5K - 3K revs then starts boosting again, not a very smooth boost curve! N75J valve can help smooth this out, much more aggresive boost valve! Assuming thats what ur talkin about?? :?
charlievwp
Post by charlievwp »
brad mole wrote:do all the mk7 polos have the temp gauge or just teh gti, 'cos i dont think mines got it, same with the trip computer thing that tells you your mpg etc.?
Mine too :cry:
I'm not sure that i'd wanna see what mpg I get though anyway! :roll: :lol:
TDI_Burd
Post by TDI_Burd »
i was at -5 the other morning
whitegtipolo
Post by whitegtipolo »
so jeff at -2 deg outside temp thats what you get into your engine?? which sensor measures intake temp??
Jeff GTi
Post by Jeff GTi »
white, im not saying thats gospel, but seemed to be the pattern when the readings were being taken by forge, im not too sure where they read temps from, but know it was both sides of the intercooler, its probably best to confirm with them
