Evening all,
Was driving this evening, I felt something weird with the car... it seemed like the car was hesitating. Its not done it before but for some reason today, it felt a little juddery.
Is there anyone with VAGCOM in the Slough area or near West Norwood this weekend that I could hook the car up to and try to find out whats up with it....
Cheers in advanced....
Anyone with VAGCOM in Slough or South London?
I managed to put my car on a vagcom... these are the results.....
17978.Engine STart Blocked by Immobiler (which was highlighted)
16514.Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
16555.Fuel Trim: System Too Lean: Bank 1
17511.Oxygen (Lambda) Sensor Heating: B1 S1 Performance too Low
After doing a little research, I've learnt that I have to clear the codes before getting it re-checked. How do I clear the codes?
Petar001
you can clear it and then drive it few days if same codes are shown Then you need to change Lambda sensor !villieb wrote:I managed to put my car on a vagcom... these are the results.....
you connected to vag com then when you go to show errors you have clear option
